315 70 17
My plans are to run 285 70 17 when my factory BFG's are needing replacing. I figure this would be a good compromise without having to change gearing/lift....
Hope this helps,
Scooter
When and if you get the tires post some pictures. I really would like to see how it looks without cut flares.
https://www.jk-forum.com/forums/show...flexed+picture
Check out this tread.. This guy has stock suspension with flat flare and he is running 35's.
Both. I have since changed to a RC 3.25" kit.
Damn! get the tires! -dont pass up that deal.
Just trim or bend the pinch seams and lift it more when you can.
If you trim your flares and use the rear TF bump stops you will be good to go. It's not necessary to add any additional bump stop to the front.
Love that deal! Wish I'd stumbled upon it!!
I'm looking to put the same size on my 2010 Sahara after my 2.5" Teraflex goes on next week. Based on what I'm reading here, I'm in for the same rubbing, right?
In reference to the pinch seam, does it actually rub on them at full flex, or is it just really close? I can live with it just being close, but if it rubs, thats another story.
Thanks
Thanks
