3 new steering stabilizers fail in a row. Lifespan = 3 days each
(See pix below)
HISTORY: I got a BDS 4.5" adjustable CA lift which came with a BDS steering stabilizer. I know the shop relocated the axle side mount.
RESULT: The first stabilizer failed in 3 days it was leaking like a siv and had a dead spot after being removed. Shop installed another one (new one but same part ). It had the same problems and lifespan. Just the other day I ordered and installed an old man emu stabilizer with the same mount locations and it also is blown and leaking bad after just a couple days post install.
QUESTION: Is there something wrong with the mounting points for each end? I have seen other mount methods compared to my setup. Other thoughts on this? Taking it back to shop next week. Thank you -Aaron
![](http://i197.photobucket.com/albums/aa317/atownpdx/68B6B265-149C-4184-ACAA-826A44A9E82E-384-00000031F8A45FB5_zps09b685ad.jpg)
![](http://i197.photobucket.com/albums/aa317/atownpdx/23F807EB-EAC6-4E5B-87DC-0CDA6210177C-384-000000320931552C_zpsbb7ccdc6.jpg)
![](http://i197.photobucket.com/albums/aa317/atownpdx/C0FB6F88-03C8-414B-A6BF-65D281C88894-384-00000032177A8F7E_zps65d964e4.jpg)
![](http://i197.photobucket.com/albums/aa317/atownpdx/A0AB1BB5-3552-43F7-9398-9F031EAD9344-384-0000003226FCEF15_zpsa0ad7c66.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_marine_corp.png)
The mount on the tie rod has to be in the correct location or the steering stabilizer will bottom out or over extend causing damage to the seals and ruin the stabilizer. like shocks you have to pay attention to the compressed and extended length and mount the tie rod mount in the correct location.
Take that boot off (don't need it) loosen the tie rod clamp.
Turn steering wheel all the way to the passenger side. Move clamp in/out so about 1/4 of the shaft is still showing. Tighten clamp. This should give you enough travel and not keep blowing the shocks.
RE: the shop reputation. I have not had the best experience but I haven't heard much other neg feedback. Except this weekend I heard someone mention that their SS blew our shortly after install from same shop.
Thanks on the reco about lossening the tie rod mount. Trying to weigh whether to send in the emu under warranty and then install new vs have shop look at it and install another BDS. Maybe I will just do what was said w the current bad one in place and try to see how off it is.
Ps does the angle if the SS between the frame to tie rod matter?
Thx for all advice!
Thx for all advice!
