3" long arm lift with longest travel
Old 08-22-2010 | 01:24 AM
rubi08unlimited's Avatar
Default 3" long arm lift with longest travel
What long arm lift in the the 2.5" to 3.5" range has the longest travel? I'm looking to stuff 37s. I already have flat flares so all I need to do is the pinch seam mod and I should be able to fit 37's. Also, with only 3" of lift, will I need to limit my travel with bump stops or will I be okay? I want maximum travel so if I need to use bump stops, I would rather go with a 4" lift if i need to to gain articulation.
Old 08-22-2010 | 05:17 AM
jeepywave's Avatar
my recommendation is the rock krawler i have a friend with it and it is top notch all abuse proof and indestructible. They will be coming out with shocks soon to help gain a little more articulation out of the system.
Old 08-22-2010 | 05:27 AM
Biggy's Avatar
With any lift in the 2.5 to 3,5 range, your going to need bumpstops if you want to run 37's. I have the 3.5 RK mid arm with 37's and I can't say enough good things about it. As far as bumpstops I have 3 in the back and 1.5 in the front and also flat flares
Old 08-22-2010 | 05:35 AM
That's what I'm leaning towards is a 3" triple threat from Rock Krawler but I want to know how the articulation of that system compares to other systems out there. Will I need new driveshafts with a 3" lift? The Rock Krawler system looks pretty complete so I'm guessing, that shocks, a gear job, wheels and tires should get me up where I need to be. What is the travel on this system and who else is running this system and what did you add?
Old 08-22-2010 | 05:50 AM
Biggy's Avatar
MY unlimited is fine as far as driveshafts are concerned. All I added is OME LT shocks . As far as travel. You will have no trouble fully stuffing your tires with this lift. My friend has the triple threat with bilsteins and he's happy with it.
Old 08-23-2010 | 06:16 AM
Phishjeep's Avatar
3.5 RK Long Arm with Bilsteins, stock flares, and 35" mug grapplers. no bump stops, and the only rubbing is the slightest kiss on the rear stock bumper. Looking to run flatties and 37s one day, without bumpstops. We'll see.
Old 08-23-2010 | 06:17 AM
Phishjeep's Avatar
Oh, and unless you're racing on desert, you don't need the triple threat. The front 3link works well on and off road.
Old 08-23-2010 | 07:10 AM
Pluke the 2's Avatar
Did you see Planman's set up?
https://www.jk-forum.com/forums/show...hlight=planman
Get a kit with some Long Travel Shocks if you want articulation..
If you want to go with 37's you can always run a LCG on 37's. Articulation will be there.
Old 08-23-2010 | 07:29 AM
I didn't know they had another option. They have 2 long arm 3" liffts?
Old 08-23-2010 | 07:41 AM
nevermind, I found their other kit. Can anyone suggest some reading on how the 3 link vs. 4 link works?
