3" Lift plus 35's = Driveline issues???
Your double screwed, Like WOL said with the auto the front boot will get torn on your driveshaft.
Since you have SWB your rear shaft will need to be replaced after time. You might get several thousands of miles out of it, or it might blow up tommorrow.
Depends how much you wheel, how well your rear pinion is lined up to transfercase.
JK-Forum Founder
no offense but that really doesn't look like a whole lot of flex to me and maybe about as much as you might see if you didn't disconnet your swaybar links. if you are not disconnecting your sway bar links when off roading or have front shocks that are on the short side, this will prevent you from obtaining enough droop to cause your axle to swipe over and make contact with your auto tranny.
just so that it's 100% clear, IF you have an automatic with 3" of lift or more, with shocks long enough to give you greater flex and you wheel your jeep with the swaybar links disconnected as you should, your front drive shaft WILL make contact with your auto tranny and it WILL tear the spline shaft boot. there is NO exception to the rule here. how sure of this am i? just do a search and you will see this is a common problem. also, i have a corner of my garage stacked with about half a dozen front drive shaft boots that have been torn. why do i have these? because i've helped about half a dozen people change out their front drive shafts after tearing this boot. need i say, i am speaking from experience here and NOT expressing an opinion.
you should really take a look at the rustys 3.25 lift for the jk. Its the lift im going to go with and from what iv polled from all the rustys users on the forums there customer service and product quality is outstanding. You get front and rear adj track bars springs and shocks for 550.
I am a trail rider / offroadert that for the Florida flatlands that I ride have never disconnected my sway bar. I installed a Black Diamond 2" spacer kit and currently run 33" tires. I have an automatic transmission and am considering running 35" tires. Judging by this thread, I am guessing that I would be ok with the factory front shaft. Is this correct?
JK-Forum Founder
