3" Lift
#22
Kit # 1256200 has everything that 1251200 has, but also has front lower and rear upper control arms. As I'm sure you've read on other threads is that you really shold get these 4 control arms. This kit with the arms will let you adjust front caster which will allow your jeep to handle better on the road. The rear uppers let you adjust your rear driveline angle so your rear DS doesn't wear out. To answer your last post, yes it is worth it to get these 4.
Also to consider is kit # 1451300 which include all 8 control arms. With the additional 4 control arms in this kit, you can reset your wheel base. Remeber as you lift the jeep the wheels will want to tuck in towards each other, and your wheel base shortens ever so slightly. Also the TF control arms are much beefier than the stock ones and are greaseable.
On to track bar. With any of these kits you'll get a rear trackbar relocation bracket, so you don't need to worry about the rear. The front is another matter. From installing this kit, I definately needed an adjustable front. My axle was shifted way over to the driveside. It's good practice to have your axles centered for handling and honestly it just looks chincy to have your axles misaligned. TF has a good one, or JKS has one. Check those out.
Check out this thread on your backspacing question.
https://www.jk-forum.com/forums/show...74&postcount=3
The stock backspacing is 6.25". I have 1.5" spacers which puts my backspacing at. 4.75. I've had no rubbing issues. It seems the consensus is 4.75" of less. So you can split that between the wheel and spacers. You could get your wheels at 5.5" then add a 1" spacer to achieve 4.5", perfrect.
Let us know what you decided!!
#24
Im going to save for a while and get the one with the 8 control arms. I though spacers cause wobble? Plan on getting the fron trackbar too. Just hope the shop knos waht to do with all them. They reccomended and installed a basic 2" BDS lift on my TJ with spacers and i had a vibration when going down interstate Thanks for the advise
