3 Inch Suspension
Old 11-16-2014 | 07:07 AM
Texasjku13's Avatar
Default 3 Inch Suspension
I have a 2013 Sahara Unlimited and I plan on ordering a 3 inch Taraflex suspension lift. Can I use run the 255/70/18 Bridgestone Dueler now until I purchase 35s? What else do I need to consider when lifting with these spec?
Old 11-16-2014 | 08:38 AM
TheDirtman's Avatar
research, its all on here just look for it in the stickies.
Old 11-16-2014 | 09:30 AM
Texasjku13's Avatar
Ok let me figure out what a sticky is. Thanks
Old 11-16-2014 | 09:33 AM
TheDirtman's Avatar
At the top of this page you will see the words modified tech, click on that and look at the top posts marked stickies. There is also information in the new member section
Old 11-16-2014 | 11:34 AM
Tooadvanced's Avatar
To give you a direct answer it is yes. You can run those on a monster truck. Will it look funny? A little.
Old 11-16-2014 | 12:39 PM
Texasjku13's Avatar
I agree. It's best to be patient and do it all at once. Thanks
Old 11-16-2014 | 02:35 PM
nthinuf's Avatar
Yeah, they are hidden and really hard to find without having them pointed out. When you first click into the Modified Tech area, right at the top you will see a few threads with a gray background that say something like:
Sticky: Modified Tech FAQ's - Answers to questions every newbie has
Sticky: My Thoughts on Lifts
These will answer a bunch of questions, and probably give you a dozen more that you hadn't even thought of.
Old 11-16-2014 | 03:42 PM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
If using a phone app, they are under the "Stickeys" tab at the top of each subforum.
Quick Reply: 3 Inch Suspension
