3 inch body lift?
Old 12-21-2011 | 11:26 AM
RonFDNY77's Avatar
Default 3 inch body lift?
Trying to find 3" body lift. Looking for inexpensive easy install. Someone told me 3" body spacer lift but can't really find one. Not too familiar. Any ideas???
Old 12-21-2011 | 11:28 AM
jtjk's Avatar
the highest iv seen in 2.why do u want to use such a large body lift? throw leveling kit on or a 2.5 puck kit, maybe add a 1 inch more body lift and be done with it.
....i asume this is to fit big tires.
Old 12-21-2011 | 11:35 AM
elitecontrol's Avatar
I would try to stay away from anything larger then a 1 inch body lift.
you'd be better off with a spacer and 1 inch BL. plus it would be an easier install.. 3 inch would require major extensions of things.
skip it, go 1 inch BL and cut your fenders..
Old 12-21-2011 | 11:39 AM
Monte417's Avatar
A 3" body lift would look kinda just sayin
Old 12-21-2011 | 11:45 AM
arasco85's Avatar
I know this doesn't answer your question but that will be a pain.in the ass. If you wanna keep it economical get spacers for your springs. Also way easier and you don't have to mess with your bumpers being 3 inches lower.
Old 12-21-2011 | 11:52 AM
drivingfool's Avatar
You going to do it yourself? There's a few jeep shops and mechs around. The JK suspension is actually pretty decent as is and a leveling kit is a great mod for better looks. If you're going to put on bumpers/sliders/winch/skids, that's anywhere from 250-400 pounds depending on how crazy you are, that's where a big suspension lift kit is gonna pay for itself.
If you go to bigger tires you have to get your jeep reprogrammed so the speedo knows whatsup.
PM me if you need some local info.
Old 12-21-2011 | 12:04 PM
gluestick's Avatar
I am assuming you meant budget boost and not body lift at this height?
Aside from the negative cosmetics of a 3" body lift on your Jeep, you are raising your center of gravity significantly, and not in a good way.
Old 12-21-2011 | 12:12 PM
Battlefrog's Avatar
I could be wrong, but I think that pose a huge problem with your shifter assembly. Im guessing you would need a longer shift rod and some other components to make it work...
RonFDNY77's Avatar
I guess I was referring to spacers. I want to lift it for now not too much but enough. Larger Tires would come eventually. I just wanted to get lift with as little suspension mod as possible. Hue high can I go with spacers. Sorry. I really don't know much of what I'm talking about. Just want to raise it and I expensively. I won't be doing serious offloading so don't need anything crazy. Make thAt no suspension mods. Lol
Old 12-21-2011 | 12:28 PM
RonFDNY77's Avatar
Ok found 2.5 inch rear spacers but no front guess I would need a leveling kit instead. Do they even have 3"
