3" Coil Lift - Need Legit Advice
Question:
-What are the disadvantages of getting a 3" lift kit that only includes the coils?
-If I get the 3" kit that is coils only (of course I would buy a front/rear adj. track bar), how are my control arms affects? How is my offroading affected? How will my JK handle on the street, highway and turning?
Thanks!
Please list any comments and suggestions you may have on this. I really want to get the Full Traction 3" economy kit that is the coils only and then get the JKS front and rear adjustable track bars. But know this, I am a young guy with very very little money. I ain't rich. But I love my JK and I love offroading. So I need to be inexpensive, but still affective. Also I already have Rubicon Express 2" puck spacers that I want to get rid of.
Thanks!
JK-Forum Founder
if you have a two door, you really should consider getting a new rear drive shaft sooner than later. and, to do that, you really need to get adjustable rear upper control arms so that you can set your pinion angle. now, while you would be perfectly fine without any adjustable front control arms, a lot of people find that the steering at highway speeds is somewhat 'flighty' and the only real way to address this is by adding more positive caster. in other to do this, you will need at the very least, a set of adjustable lower control arms up front. along the the lines of a 3" lift, if you have an automatic, you will tear off your front drive shaft boot when flexing and so you will need to get an aftermarket u-joint style shaft as they are much narrower. aside from that, you really don't need anything else and you should be good to go.
WayofLife...I am now officially scared.
So what do you suggest I do, in regards to keeping my lift inexpensive but still affective and not hurt my JK?
JK-Forum Founder
if cost is an issue, i would recommend that you just do something like a teraflex 2.5" budget boost. it's cheap, will get you up on 35's and comes with pretty much everything you need to make it work.
It's less than$600 with shocks.
I assume you want to be able to clear 35s? Here's a pic of the setup I described with 35" KM2s. It's sort of a big picture, so I'll just post a link.
http://i307.photobucket.com/albums/n...K/DSC01071.jpg
Is it possible to purchase just the font coils for the 2.5" coil lift? I originally ot a BB lift but now that I've added weight to the front, the front end droops so much. I feel like I'm driving a scoop shovel. I'd like to get it to level out. I've seen pepolpe add the leveling pucks, but that would be like 3 up front which makes me nervous. Any advice?
You tore your DS boot just with a 2.5" coil lift? Which new DS did you add?
