3.6 owners only!!!!!!!!!!
#51
25k, not so softly driven miles,Robles free. In fact, no issues with anything, yet....... The reliability of my '12, beats out my land rover, dodge ram and ford ranger I've owned over time. In fact, the Landy was the absolute worst. Just a tic under $24k in repair/replacement for major issues. Additionally, it's only been in once, for the trans cooler line recall, which was not needed, but required once it hit their doors.
#52
#53
This is yet another gearing thread. But I think I want something different. I want info on your rig. Even if you are still running stock gears and tires I want to hear from you. If you have upgraded I want to hear from you also. This is what I am looking for.......
1 - What gear ratio are you running?
4:10
2 - What tire size & Brand are you running?
37" cooper discoverer stt
3 - At 70 mph what RPM is your engine turning?
2200-2400. The problem is it shifts in and out of overdrive more frequently because I didnt regear
4 - Are you using the AEV PROCAL or Superchips Flashpaq?
No
5 - On the road what is your opinion of the performance?
Never had anything else. I walk all over the 3.8l for performance
6 - Off road what is your opinion of the performance?
Doesn't freeze frame movement much like it did with stock wheels. As in its jumpy and not responsive as much to the feather footing. Nothing to be concerned about. Minuscule difference.
7 - If your fairy god mother came to you and said you will get any tire/gear package you want would you change and to what?
4:10
No
#55
1 - stock 4.10 ,manual 6 sp.
2 - Goodyear Wrangler Duratrac 315/70R17
3 - around 2400 RPM at 70 mph,
4 - speedo has been recalibrated by the dealer for 33'' tires (real measurement, my tires measures 33.75'' at 32 psi) Speedo seems accurate as per my Garmin GPS.
5 - Performance has decrreased a bit over stock but nothing to worry about
6 - Off road performance is ok and I have the rubi Rock track T-case so low range is still very low.
7 - I would redo the same mods again, very satisfied with the result.
#56
If I commuted 4.88 would be better, but I prioritized for off-road
It's not driven everyday
Matthew
#57
B. Procal is for gearing. Flashpaq is for tuning. Do you mean Flashcal?
C. Offroad could mean anything. Rocks to forest roads. You should ask what type of off-roading they do.
#58
off road: sand (soft & silty or course and gravelly), musk, glaciers, deep mud, hills, flats, packed roads, clay mud. Yep! It can get sticky!
#59
So I had them installed yesterday. So far I like them but during the break-in cant really "drive" it. Once I get the break in done and change the oil hopefully I can get a better feel for them and see if it was worth the $$$$!
#60
2 Door 2013 Manual
1. 4:56
2. GoodYear Duratrac 315/70/17 33.75"
3. 2500+
4. Superchips Flashcal
5. Great gas mileage around town, not so great on Hwy
6. Just got lift and gears done. Haven't been off road yet.
7. As far as my needs go, DD and trail/beach, this setup is perfect for me
