3/4 spacers with lift
Has anybody installed 3/4 spacers to try level out 3" full traction kit .I would like to get the front up a little more have the M- force shocks i would think they would be plenty long enough also have adj. front track bar comming.
Adding 3/4" spacers up front is quite common on any lift or even without any lift but the one thing you should be aware of is that your caster will only be that much more off afterwards (almost 4" of lift). If you don't have them already, I would highly recommend installing a set of adjustable front upper and lower control arms to help correct your suspension geometry and adjust your caster angle if you're going to do this.
