3.21 -> 4.88: What should I expect to "feel"
You will mostly notice it when your off-road in 4-low
i have a stick with 5.13 and 37's and it's great off-road, climbing hills and going over obstacles is a whole new world...I had starts with 3.21's
i describe it as riding around in a go cart or maybe a dune buggy
i have a sport and my on my short list is getting either a rubicon or Atlas II transfer case
matthew
matthew
Yes, I realize that the transmission will down shift. I just never noticed it with the 3.21s. Is it normal to feel it at higher (numerically, ie 4.88) gear ratios?
I think the answer is yes.
I went from 3.21 to 4.88 on a 2008 X with manual trans. It seems to me the engine is reving higher to maintain the same road speed with the new gear ratio. You will feel the engine working harder at the same speeds with 4.88 relative to 3.21 gearsets. Just my 2 cents based on my experience.
It is more harsh in the lower gear.
Now your automatic's downshifts are more harsh, or more noticeable.
Daily driving should not be that much different, starting from a stop will take less effort and you will handle most highway speed grade changes with downshifting. The jeep should feel a bit more sprite and I am sure your foot will adjust to the throttle over the first couple of weeks.
Off road is where it is really going to show, you will drive slower and in more control over obstacles and should feel more like a race car when you do want to get on the throttle, quickly raving and spinning the tires. You will not bog down on steep climbs or in the mud and will be able to power thru those things.
Off road is where the money is really at. I love crawling in this thing in 4lo. The dunes are awesome in 4hi, but I do the on the fly shift so I can control it from shifting to early and losing momentum causing me to get stuck going up hill and possibly causing way bigger problems. An LS3 would help solve that, but don't have the money just yet.
Swapped my gears out at 3k and never looked back, so glad I did it.
For the type of wheeling I do, first gear is more than low enough. I suppose I would just go up a gear with a rubi t case (ie: instead of 2nd use 3rd) so it wouldn't be a big deal.
