2'bb but what tires
33s are a waste, you will want 35s anyway plus a 33 is not much bigger than the stock size.
3.21s are doable with 35s with the OD off. I run 35s on 3.73s with the OD off and its fine. As long as you get an AEV procal or superchips or something similar to correct the speedo and shift points (if your an automatic) Drive it first and see if you really think you need gears. I honestly dont think I will be doing a gear swap
And 2.5 BB is PERFECT for 35s. The 2.5 in teraflex BB comes with all the parts you need and with TF's bumpstops I do not rub AT ALL and I wheel it pretty freakin hard
LOL thanks
i personally know 2 guys in my area that I wheel with, both have 35" goodyear mtr kevlar on the Teraflex 2.5 inch lift AND the 3.21 gears manual tranny and they have no problems. 6th gear will become useless (same as running with the OD off)
good to know of people actually runnin' something and not having any problems. thanks for helpin a girl out... i can't wait to start shoppin for tires! probably need rims too? have the S package, so i think that is 17"...
If you get aftermarket rims with a backspacing of at least 5 you dont need spacers.
Also you will find that with a smaller rim, the tires are cheaper. For example the tires for a 15 inch rim are about 200 each and tires for a 17" rim are about 300 just FYI
Here's a link to the FAQ section, should answer any other questions : https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
