285/75R17 or 315/70R17 ??
Old 09-17-2013, 02:27 AM
  #61
Philip *AZ*'s Avatar
Originally Posted by bobholthaus
So there's no way to run a 35" without a bigger lift? If I read the above correctly, trimming the pinch seam may be okay for onroad use. Offroad, I'm going to rub even after trimming. Is that correct? And if the tires run closer to 34", will that make a difference? Thanks guys.
Here are my 33"s stuffed up in the back:
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=498211"/>
No, trimming it is the point. You shouldnt hit it after trimming it even with no lift and 35's. Mine isnt trimmed, but I think I get away with it because my lift pushes my axle back by 1". I may trim it anyway just because i dont like that sharp point anywhere near my tire. Its not likely I would ever hit it, but Im not willing to take that chance. Ive stuffed my tire in there as far as I can get it without a problem, but Ive always looked at that pointy lil sucker. Even thought about just taking a sledge and folding it over, but it only takes a sec to trim them.
Old 09-17-2013, 03:59 AM
  #62
WARLOCK's Avatar
You can run 35 with no lift but you nead at least: flat fenders, trimmed air dam and pinch seams. With rear adjustable control arms you might not need to trim your pinch seams.
Rockkrawler control arms moves the rear end back 1" that is the reason you don't need to cut the pinch seam with 35. But looks like it moves too far and you hit the rear bumper when flexing.
Old 09-17-2013, 02:00 PM
  #63
I hit more than that. Thats why Im modifying that bumper and gutting the rear fenders. It will look good when Im done. Its all temporary until I get a tire carrier.
Old 09-17-2013, 02:04 PM
  #64
Firemedic65's Avatar
Is the 315 tire gonna fit on the stock mount?
Old 09-17-2013, 02:17 PM
  #65
WARLOCK's Avatar
mine did not fit on stock spare carrier. I purchased the teraflex HD hinge with adjustable carrier but not installed yet. Pretty good reviews on this product. A litlle bit expensive but you get what you pay for.
Old 09-17-2013, 02:22 PM
  #66
I'm using stock wheels tho? Same thing?
Old 09-17-2013, 02:24 PM
  #67
It will fit.
Old 09-17-2013, 02:30 PM
  #68
Originally Posted by Philip *AZ*
It will fit.
Cool. After buying these tires I won't have money for that lol
Old 09-17-2013, 02:35 PM
  #69
Originally Posted by karls
How? Do you have longer control arms in the back?? Below is a picture of 35's on stock control arms (passenger side in front of the wheel) and you can see how close the tire is to the pinch seam without even flexing it out. My thumb is on the rubi rail and the color is the pinch seam where it should be cut.
Sent from my DROID4 using Tapatalk 4
Here are my pics with my uncut pinch seam
ID:	498323   Click image for larger version
Old 09-17-2013, 02:45 PM
  #70
I tried to get better pics, but the iPhone camera is shite when its bright outside. So I roughly have 3-just over 3in of clearance between the pinch seam. It may get cut any way. But Im in lazy mode right now and dont feel like doin anything...lol
Quick Reply: 285/75R17 or 315/70R17 ??
