275/70/17 stock rubicon
will a 275/70/17 tire rub on a completely stock rubicon? has anyone used this tire size? i cant find 32s here its the closest i can find... would I need spacers? becasue if i do theyre 400 dollars here...
Here is a link to a rim and tire size calculator it will allow you to compare new sizes to stock:
http://www.rimsntires.com/specs.jsp
Stock rim and tire sizes can be found in this FAQ:
https://www.jk-forum.com/forums/show...274#post211274
If you do have a slight rub when the steering wheel is turned fully to the left or right here is a cure:
http://project-jk.com/jeep-jk-write-...top-adjustment
