25 psi in a 35 too low??
I run 32PSI in my 35's and noticed that the front likes to bounce a lot when I go over bumps. I thought it might be the suspension and have been trying to track it down.
Any one had the same problems with 32PSI??? I am going to try airing down to 27psi and see if that fixes it.
I was running my 35's at 30 PSI and found that the ride was a little bumpy. I dropped it down to 28 PSI and noticed a improvement. I plan on doing the chalk test when the weather clears up to get that sweet spot.
I dialed in using the chalk test (or grease pencil in my case) and "seat of the pants" comfort test. My Goodyear Kevlar MT/R35s and I like 24-26#. Now also pay attention to people's load range. Mine are C. If you have higher, I'd imagine they will be a rough ride no matter where the pressure is.
Discounttire aired mine up to 40 psi... Said I shouldn't have it lower on the street than that?? Ride seems hard but not unbearable... Thoughts, should I lower it, say 5 psi at a time??
