22 psi too low for street?
i recently did the chalk test on my tires. at 22 psi im not nearly getting a full contact patch, large portions of each side of the tire are not touching the road. im weary to go any lower than 22. what do you guys suggest i do?
Also if im going to 20 on road how low can i go for off road use. as far as i understand it single digits requires bead locks
I run 22-25psi in 40"s (load range C) on the street. I initially ran 28-30psi when I first got them and it was a horribly rough ride. Took them down below 25psi and it made a huge difference. No problems with the tires feeling too soft or squishy in turns, sidewalls look about like you want them for the street, and the contact patch after a quick chalk test is just about perfect for even wear at all four corners. My 4 door is fairly heavy too with the ProRock 60's. I would not think that 22psi is too low, especially on load range E tires
Load range E minimum pressure: 35 psi
Passenger (p metric tires ) 26 PSI minimum
Metric tires 22 psi minimum
