2015 Rubicon JK w 4" Lift & 35s - left pull, squirrelly at speed
#22
If that LCA is damaged then I suggest you get it on a rack and do a corner to corner measurement check. Just a 1/4" difference can make a vehicle pull one way. A shorter LCA will pull the diff back a bit. Have someone follow you and observe for crabbing.
#23
A lot of people noting a consistant issue with a specific tire doesn't mean everyone has the issue. But there are enough cases out there including many types of vehicles, some with no lift at all, to indicate something is afoot - especially when switching to a different brand of tires resolves the issue.
#24
Will do. I'd like to replace those LCA anyway, when money allows.
#25
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
I have several years first-hand experience with 37" Trail Grapplers in addition to having many buddies on the same tire from 35 up to 40s. Never seen an issue with these. I've never searched, but I'm a little surprised to see the results you found. Odd. Nothing says any tire can't get uneven wear due to various reasons though and then cause issues like a pull.
#26
