2014 JK Rubicon Transfer Case noise
I have a 2014 Rubicon 2 door with a manual. Only have 17,000 miles on it. I am not having any issues in 4wd, it is performing fine off road in 4 hi and 4 low. The thing that concerns me is the noise that is coming from the transfer case. It's just like a little racket, like you can hear the chain spinning. It does this in 2 wheel drive just sitting there at idle. I mean it is not terrible but it is noticeable. I'm thinking it's normal, but is anybody else's Rubicon TC making this racquet?
If you are getting the noise when you are not moving it is not coming from the transfer case. If the Jeep is not moving then the transfer case is not moving either.
Sounds to me your hearing gear roll inside of your transmission.
If it was the throw out bearing you would hear it when the clutch pedal is pushed in thus spinning the bearing
Nothing to worry about kind of what the NSG-370 trans does time to time
The noise goes away when i push the clutch in. Is this something i should worry about? It doesn't bother me, but if it needs fixed then the jeep is still under powetrain warranty.
Mine does the exact same thing every now and then.
I will say if it is really loud it might be worth a visit to the dealer if you are still under warranty
No nothing to worry about that's exactly how it should happen....push in the clutch pedal and that stops the transmission input shaft from spinning which in turn makes the noise go away.
Only reason I believe it's nothing to be worried about is that when I had my HD Road King it would do the same thing in neutral so I knew what gear roll over sounds like.
Some owners report changing the gear oil helps reduce the noise which I plan on doing this spring.
Of course the dealer is going to say it is normal, and you may never had a problem with it, but definitely have them check it so you can document it if it does become an issue.
These transmissions are definitely noisier than many other manuals out there.
