2013 TPMS Compatability
that is true but you have to have the correct package for it to work that way. I have a base sport and it does not give individual tire pressures. I did test drive an upgraded model rubi and it did.
Does the '13 owners manual give you advice about what to do when you rotate tire positions?
Does it automatically re-learn which tire is in which position? Or is there a reset procedure described?
Or are you at the mercy of a shop with the special tool?
Thanks, Guys, very interesting. So the '13s can, if equipped, tell you which tire is low.
I got a '13 manual and reviewed it. Confirming and expanding upon previous posts:
There are now Base and Premium TPMS available.
Both will indicate a bad sensor or a low pressure (same as the older systems) but now each will indicate position on rig of the low pressure tire.
The premium (on vehicles with EVIC) actually shows the pressure of each of the 4 tires being monitored.
Neither base nor premium monitors the tire in the spare position.
Rotating the tires (or employing the spare to replace another wheel) causes the system to reset if you drive for "up to 20 minutes" at over 15 mph. (that's an increase from 10 minutes driving time noted in older manuals)
No mention of the current sensor frequency.
No mention of compatibility or not with the 315MHz or 433MHz sensors found on earlier models.
I can confirm that the newer 2013 sensors and system work on a different frequency than previous models. They are NOT interchangeable with the previous model sensors, and vice versa.
The above is correct. Just ordered MB TKO's from DTD and they sent them out with the 2012 sensors by mistake. I caught it on the invoice, and they had to turn the shipment around to put in the correct sensors. All 2013's operate at the same frequency whether they have the individual read outs or not, but are not compatible with earlier systems.
I know this is an old thread, but I'm about to pick up a set of 2012 jk alloys for my 2013, and was wondering if the tpms from my factory wheels will fit and work in the 2012 wheels I'm picking up? Before anyone asks I'm buying them because they are already powdercoated. Thanks!
Your original 2013 sensors will fit in 2012 JK wheels and work fine on your 2013 JK.
If you get the warning light at first you may just have to drive at over 15 mph for up to 20 minutes.
