2013 sport P258B code
Looking for help with a P258B Vacuum Pump Control Range/Performance DTC, NO CEL.
Other note Jeep ran normal last night, today noticed a small puddle of washer fluid, looks to be the washer fluid pump failed. not sure if this is causing the code?
Vacuum pump is still in the stock location. 2013 Wrangler Unlimited sport with 90K miles.
P258B can be due to:
Good luck, and keep us updated. This doesn't seem to be a common code/issue, so I'm sorry I can't be of more help.
- Powertrain Control Module (PCM) failure
- Vacuum pump failure
- Vacuum pump relay failure
- Wiring issue
rhodeislandfamily (10-29-2022)
just putting this out there for anyone who may need it.
vacuum pump is more than likely toast.. probably corroded and/or plugged the lines. swap in a new one and make sure youre hoses are not plugged when you do.
