2012 tuning
2012 tuning
I'm by no means well versed in this sort of thing, and my search didn't pull up what I was looking for... maybe someone can educate me... but if the Challenger is rocking 305 HP with the Pentastar, would it not be a matter of someone like Superchips building a module to reprogram the JK's Pentastar? Or is it not as easy as I make it sound? I am assuming torque remains the same regardless? Or am I wrong there?
Thanks!
Thanks!
The companies like bully dog and superchips are working on cracking the codes for 12s to adjust power and what not. The problem is two live axles 4 wheel hi and low transfer cases etc. Your pentastar is not tuned for a challenger... A challenger is not tuned for your jeep.
Fueling, shift points, yada yada. Completely different.
Those companies will eventually make your rocketship faster. Be patient. :-)
From what i read the difference in the output is only based on the intake and exhaust set up. The challenger has dual exhaust and longer intake tubes or something like that. I even read that the fuel mapping is the same program etc. This is what i read.....if its true or not i don't know.
305 horses or not, by the time you finish modding your rig, you'll be kissing away like 50% of that power away by the time those horses make it to the rear wheels.
