2012 Rubicon regearing
Originally Posted by mattgt5
A procal will not change the performance of your jeep. It will tell you how fast you are really going and it will turn off your tpms if you dont have sensors, plus a few other little things. It is not an alternative to gears if you are looking to regain lost power
Yes, get the ProCal. I have used it on my 2012 JKU Rubicon with 35" tires and it works like a charm. I will use it again to readjust tire size when I put on 37" tires.
When the computer has the correct tire size information, it will adjust the speedometer and indirectly adjust the transmission shift points because the speedometer will be accurate again. If the speedometer is off because the tire size is wrong, the transmission will shift at the wrong time. You could also have problems with the computer nanny engaging and causing some weird driving experiences because the axles will be spinning at a different rate than what the computer expects if the tire size isn't adusted.
Originally Posted by bob-o
But with the new pentastar it doesn't really lose much power when switching to 35's or 37's. When I get on the throttle pretty good at a stop light, I actually break traction a little bit on 37's and auto trans
I do believe the tranny shifts off of rpm and not speed, lol!
