2012 Rear Drive boot torn/AEV Lift question
Tooling around the black hills this weekend, i ended up tearing my rear drive shaft boot on the evap canister skid. I know i should get a new shaft, but that would require UCAs. I talked with AEV today, they recommended that i just move the evap and skid and replace the boot. They said if i change out the control arms the ride quality would suffer with their SC 3.5in lift.
I would like your thoughts on AEVs suggestion.
Thanks
Thanks
JK-Forum Founder
Thanks
Thanks
There is a thread on here about relo ing that skid. Tf has a video on it. Thay is what i would over a new ds. For some reason, my boot is not that close to the evap. Go figure.
Attachment 357113
Attachment 357113
I started a thread on this almost a year ago. There was not a lot of lifted 12s yet put the max travel kit on flexed it out heard this awful noise looked under ripped the boot. I had a e-vap skid form my 09 jeep so just put that on all good but going to need a rear shaft sometime i stay out of mud so hoping it will stay quiet for a while.
Thanks
Thanks
FWIW--I've been running my torn rear boot for 8000 miles now.
Originally Posted by ,wayoflife,
you won't see the problem happen until you flex on the trail. doing so will cause your drive shaft to sweap over to the side and that's when it'll make contact with the skid. depending on how centered your rear axle is, this can be more of a problem or less of one.
JK-Forum Founder
I have had it maxed out a few times with no issues, YET. I am going to move mine as well, just havent gotten around to it yet. Maybe my axle position has something to do with it??
Attachment 357163
Attachment 357163
yup, like i said, depending on the position of your axle, this can be more of a problem or less. the problem with just running a track bar relocation bracket is that it's a one size fits all solution. depending on the weight of your jeep with mods and gear, the actual position of your axle will vary.
Thoughts
So based on this, i should continue to use the driveshaft and do the evap relocation?
I have the trackbar relocation with stock control arms. The wheel sits closer to the cab than the rear of the vehicle. I figured the Control Arms would recenter the wheels in the wells as well as allow for a Coast DS. eliminating the need to relocate the Evap??
JK-Forum Founder
