2012 JKU Lift Questions - Newbie here!
Mikemack98 if you would like I started a thread about the curious question for a new drive shaft, I believe it's best that you switch out for a new drift shaft I know I'm putting a Teraflex 3' and 35's. If you want to get some more info like I said I have a thread I started about the drive shaft.
Welcome to the forum!
FYI, as for regearing, moving up FROM the 3.21 to higher gear ratio will cost you more because the carrier for the 3.21 is different than the carrier for 3.73 and higher gear ratios. Remember to factor that into your costs.
I'm new to the modding part of this too. I had a 2009 for 3 years before I traded it in and could start to afford to make bigger modifications outside of the radio and small do it yourself projects. I learned a lot from these forums and talking to a lot of shops. Just make sure you go prepared with a list of questions, and you will soon be able to tell which shops are truly knowledgeable and those that are not.
Good luck. I've got 3.73 gears and considering the same lift and tire specifications as you are.
