2012 JKU that have regear from 3.21
First, I have a 2012 JKU AUTO with a Metal Cloak 2.5 Lift, procomp 315/70/17 Dura tracs with 3.21 gears, propaq. I find the ride OK (a lot better than my 2003 Rubicon with 35) and bearable but I need a little more. I use this as a third vehicle and travel to different locations with the family. With that being said, I am looking for highway drivability with offroad capability as well. I have read tons of post but would like first hand knowledge from someone that has been in my shoes. I am leaning towards 4.56. Dana 30 upfront and it also sounds like I will need a new compatible carrier for the gears? Any input appreciated.
1 Post
Sounds very familiar. I have a 2012 Sport JKU, 2.5 AEV lift, 315/70/17 Duratracs. I changed out my 3.21s for 4.56, primarily because I was going to add on heavy bumpers and wanted to get my acceleration back. It was probably one of the best decisions, although I do wish I had the extra $$ to put lockers in at the same time. Anyway, I really like this setup. I am even contemplating going to 37s when the time is right and feel pretty confident the 456 would be just fine.
You can get a great deal on the gears going to 4ws.com. You will need to change out the carrier since 3.21 isn't compatible.
Have the same set up as OP. After long debates i decided to go with 4:88. Its a 4 door with steel bumpers and rock sliders including the winch. 4:56 would be great too especially if you dont plank moving to 37 in the future
Hi guys
I have the same as the OP now.
Went with 4.88, while I had 33" BFG wheels.
I ONLY drive in the big soft dunes of Dubai and spent a long time monitoring speeds and rpm before doing the switch. I wanted a "4L 3rd gear" on the fly. It works very well on our dunes to pull off in the soft sand and when you need max power at a slow speed... In a hurry. I used to use 1st gear all day in the dunes. Now I use 2nd and 3rd most of the time with an occasional blast in 1st. I also regained my 6th gear.... Which a 3.21 driver knows is pretty useless. 4.88 an 33" is admittedly too much. 4.56 would be better.
I have just switched to 315/70/17 tires and 4.88 works very well with these.
I also DON'T use the Jeep for much other than off roading. So gas consumption and 2800 rpm at 70 does not bother me for the short trips I do.
There is more to a re gear than the 70 mph vs rpm chart everyone quotes.
Hope this helps.
Regards
Paul
Hope this helps.
Regards
Paul
Thank for the input, I am very content with my set-up and plan to stay with current wheel size. It sounds like 4.10 or 4.56 are my two choices. I need to find someone local with a similar set-up and thumb a ride to see what it feels like. Anyone in the Sumter Columbia area
Just installed 4.56 and love em my ride 4 door standard trans with stock rims and nitto m/t 285/75/17 which are 33.60 mounted on freeway at 75 I turn 2800 overall more responsive, happy I stayed away from 4.88s
Good luck
Good luck
Just installed 4.56's on my 2013 JKU last Friday. I run 35x12.5x17's and I'm feeling very happy with this setup on the road (it's my DD). I feel like this was the sweet spot for me.
