2012 JK Unlimited Gear Change?
Originally Posted by c17loadmaster
I have 4:88's in my auto and it runs great. If you have a rubicon 5:13's wouldnt be terrible. The problem with 5:13's IMO if you have a Dana 30 is that the pinion of a 5:13 is super small, and the ring gear is thin because the Dana 30 is a smaller housing. Problems can result. I have 35's, 4 inch lift, 4:88's Yukon locker. I get 16mpg in town and 18mpg highway.
I did rehear to 4:88's. I was just pointing out the potential problems with 5:13's. If you go 4:88's and 37's you will likely get your stock power band back, which is optimal.
I am a differential mechanic, and I tell most of my 4x4 customers to go to ringpinion.com (randys ring and pinion web site). They have a gear calculator. You plug in your info and figure out what would bring you back to stock, or above if that's what you want. Also, when you lower the ratio the pinion does get smaller (just in the number of teeth). So in order for the ring gear to make contact it has to be thicker. So really your stock ring gear is thinner. They also make different carriers to support different ratio ranges also. It's not that big a deal though. When you change your ratio you are creating less stress on the gear set anyway. Don't forget, www.ringpinion.com. and you should find out what your last gears overdrive is, and what rpm you operate in at the desired speed. You will need it for the calculations.
You shouldn't be so concerned about strength. If you want something stronger then wait for the rehearing and get some Dana 60's. What I'm saying is, what makes a differential strong is its size. That's what big trucks have big diffs. Big commercial trucks can run 7.30 ratios and that doesn't mean that there not strong. The diff is gigantic and that is what makes it strong. All you need to be worried about is ratio. Do you understand what I'm saying?
I've got a '12 auto Rubi with 37's and 4.88 done by Evo. Noticeable difference than stock gearing. Would not go any larger on the gearing. Pushing 3000 rpms at 70. Think it's perfect now. 4 Low absolutely crawls.
That seems kinda high. The stock 3.73 turn 2300 and 4.1 turn 2500 with stock rubi wheels/tires. I wonder if 4.56 would be the enough to turn the heavy tires without the high rpms.
