2012 jk 6" rough country lift
Old 10-15-2012, 05:31 PM
bombout800's Avatar
Default 2012 jk 6" rough country lift
I recently purchased a 2012 mango tango jku with a 6" rough country suspension. Ill start by saying im a virgin to the jeep community with not much knowledge of past of present jeeps. With the lift the front seems to sit down an inch or two. Im guessing factory sits the same way. Can a leveling kit be put on top of the lift without any issues or problems? Im worried about problems with any driveshaft angles, suspension angles or anything that could be damaged. Its fine the way it is, i just noticed that the front sits that much lower. Im open for opinions and or options.
Old 10-15-2012, 05:34 PM
emiles1987's Avatar
What other mods have been done? Bumpers, winch, tires, wheels, etc.... Any photos?
Old 10-15-2012, 05:39 PM
bombout800's Avatar
35 nitto mud grapplers, has a winch and front bumper, and some sort of gears. Both tags are gone from the diffs, but i havent had a chance to jack it up and rotate to see how many rotations. Ill see if i have any pics, i know for a fact I dont have one showing the different in height from the front to rear.
Old 10-15-2012, 06:03 PM
1978cj7jk2012's Avatar
Hmm. Just sounds odd to lift a jeep this high only to run 35s.. Are you sure it's a six? Did you buy it from the dealership this way? If so that most likely explains the 35s because this is generally a safe tire to run and they didn't want to make a ton of axle upgrades. Pics would be nice! and to answer your question if all the other components have been correctly modified to fifths lift you already have you should be ok putting a 1 or 2 inch coil spacer up front..
Old 10-15-2012, 06:05 PM
bombout800's Avatar
I just tried to upload from a friends mac and it keeps saying that the file is too large. I did just go out and measure from ground to fender flare both front and back. Both measure the same height, so i guess is an illusion.
Old 10-15-2012, 06:07 PM
bombout800's Avatar
pm me an email and ill shoot a pic to you. You tell me if you think it could be 4, 4.5, or 6. Im interested now, but no it was bought as used. But only 6600 miles!
Old 10-15-2012, 06:09 PM
bombout800's Avatar
i also measured from fender flare to tire and it right at 11.5 inches between both flares to the tire.
Old 10-15-2012, 06:10 PM
Creepwithjeep's Avatar
I have 6 inches of lift and 35's, I put those high clearance xenon fenders on, and when I'm out on the trails I see those fenders bending as my tires are about to rip them off when I'm all flexed out. Its not even a nice lift and I've got enough articulation to know that 35's are are my limit as well with 6 inches of lift.
Old 10-15-2012, 06:13 PM
bombout800's Avatar
When you wheel do you disconnect the sway bar disconnects? This would allow it to flex as much as possible correct?
Old 10-15-2012, 06:25 PM
Easy! I was by no means bashing or saying anything against these systems. That's great that you get such good performance. Most people just throw on a lift kit and expect it to be like Evo jeeps or WOL rigs. Although if you wanted to go with bigger tires bump stops might need to be in your future. Oh and to help the OP maybe you should post some pics of your jeep..
Quick Reply: 2012 jk 6" rough country lift
