2012 JK 33000 miles .......BAD BALL JOINTS!!!!!!!! .....maybe??????????
I have a 2012 JK sport with Rubi 18/58 springs, 1" Terraflex spacer upfront to level and 265/70/17 Nitto Terra's. Had a noise up front and put it up on jack stands with the front end hanging and found a loose upper sway bar link nut loose. Thought I had found the noise (and maybe I did) but I put a pry bar under the front tire and lifted and heard and felt a slight clunk. I had my wife keep pumpin the pry bar (yes she is good at that) and eventually found the clunk. It is my ball joints, both sides, that are moving up and down oh so very slightly. There is no lateral sideways play but there is a small amount of up down vertical play. A mechanic friend (NOT A JEEP MECHANIC) said a little vertical play is normal???????
Can I try tightening the nuts or is that a waste of time?
I realize that the JK ball joints are junk but if this play is acceptable/normal I can wait to have them done at a later date when I can afford some good after market greasable joints..........................................
Any body experienced in ball joints out there?
I'm rather versed on ball joints at this point, and can say it is very likely they are shot at 33k miles. The nut will not do anything for you. you'll have to replace the ball joints, preferably some with a metal to metal design.
Thanks for the info.
Here is a thread that will show you what's inside the OEM JK ball joints: https://www.jk-forum.com/forums/stoc...esults-116058/
Damn...........................that's why I have chosen this forum over all the other wanna be Jeep JK forum's. That was straight to the point and illustrated!............AWESOME!.................. .....other than the fact that I guess I am gonna have to go with expensive Dynatracs in the future since I am planning on keepin and liftin' this JK in the near future. Thanks for the info.
$600 for
Dynatrac? Naw. I figure the following:
$200 synergy x 2 will get me at least 300,000 miles and still come out less than Dynatrac.
That will take me till the year 2030. By then, if I even have the Jeep, it will have D60s under it and run on cold fusion with a flux capacitor.
Sent from some string and a few tin cans.
Synergy ball joints are DEPENDABLE & DURABLE if properly and regularly greased?
