2012 Jeep JK Shutting off at idle
Having a problem with my 2012 JK shutting off when I come to a stop on the trail or on the road. Problem goes away when the weather cools off. Doesn't seem to be overheating as far as gauges say,electric fan doesn't seem to be on an excessive amount. Starts right back up and may not happen again for a while. Just not sure. Thanks for any opinions out there.
sounds like a clogged fuel filter to me. after a while the fuel pump will shutdow from overheating. probably ran into some bad gas and got a pile of junk caught up in the filter. a $10 and 10 minute fix.
it still sounds like fuel problems tho.
This could be a multitude of problems. Dirty valves, dirty air filter, bad fuel, low fuel pressure, bad plugs, ECU problems, etc, etc. You can trouble shoot or rule out a good number of the potential problems by having a auto parts store do a quick plug-in diagnostic check.
