2012 ARB Compressor Mount / other on-board air options
Any chance you can post a picture, as I am thinking of this same setup for my 2012?
I had a arb compressor installed on my 2011 before i traded it in. I took it all off and ordered the new evo bracket for the 12 and rugged ridge a pillar switch pod from david at northridge 4x4. As soon as it comes in i will post up some install pictures for you.
Has RR released the switch pod for the 2012. There where a few posts stating it would not fit on a 2012???? I hope the have made changes, becuase I need one too.
Im assuming it will. If not i will be the test dummy and let you no im pretty sure it fits the 11 and the interior is the same in the 11 and 12.
I see the EVO bracket won't hold the twin on the 2012. Do you have the large or small compressor and how long does it take to air up your tires. I was looking at the twin hoping to use the EVO bracket, but I guess not.
I have the medium size compressor its not the twin but not the smallest. Its the one that comes with a tire inflation kit. I took my stock 29in tire on my 2011 and aired it down to 5psi and back up to 32psi in about 1 min it works great i will be using this compressor with my 37s as well.
pictures
can you send some pictures of the install? i just bought one an cant seem to figure out where to mount it.
