2011 auto transmission problems
Old 12-02-2015, 02:50 PM
ronjenx's Avatar
Originally Posted by ABNMEDIC
Why is it going into limp mode when the check engine light isnt on? It wouldnt even shift up a gear is that the programmed reduction in throttle response?
When the ABS/ESP becomes activated, one of the things it does is reduce the throttle setting, even if you continue the depress the gas pedal. With a reduction in throttle setting, I can't imagine the transmission would want to shift up a gear.
It all has to do with the JK thinking you are going into a skid, probably due to the steering wheel being a little out of alignment from the 5" lift. Could also be from a bad ABS wheel speed sensor lead.
This is all speculation on my part; I wasn't there to see what happened.
Quick Reply: 2011 auto transmission problems
