2011 / 2012 Dash Overlays ??
I don't know how to disassemble the dash on these jks, but if you can get to the pieces, I say go for it! The only concern I'd have is the potential for rattles/squeaks if everything isn't reassembled 100% correctly... I'm not even sure that's a valid concern.
It's more work but its also cheaper..
Pulling apart the center stack isn't too bad. Four screws and about five minutes.
Start by pulling off the panel just below the steering wheel. It is held in place by sturdy plastic clips, but comes out relatively easy. Once out, you will see a small screw in each upper corner. Take those out. The next screw to come out sits under the rubber tray in the top storage compartment (on top of center stack). The rubber tray should just pull out, held in place mostly by friction. That's your third screw. Then, pull out the power window switch panel (or cubby) in the center of the dash to reveal the fourth screw. If you have the cubby, just place your hand in it and push to one side or the other, and the clips will release right away. The screw is obvious there at the bottom. Now, the instrument surround and top portion of the center dash (all one piece, mind you) will give way with gentle pulls. There are several clips, so work your way around the perimeter and don't monkey-arm it. It will come out easily with gentle pressure. Set it aside. Next you can pull out the climate control panel portion simply by pulling from the top. More of the same clips, and it should come loose easily. Then just disconnect it. Lastly, the panel below it (with the net) will just pull out with clips holding it in place.
Good luck.
Good luck.
