2010 JK Rubicon Fox Teraflex Remote Resi shocks and Speedbumps?
or possibly replacing the upper rear pad with something like this?
Poly Performance JEEP/TRUCK & BUGGY :: Suspension :: Bump Stops & Mounts :: Daystar Urethane & Foam Bump Stops :: Daystar EVS Foam 1-3/8" X 2-1/2" Diameter Bump Stop - 4X4 Off-Road Parts, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Bra
Im just trying to sort out possible ideas while procrastinating... My JK > Finals
Sponsoring Manufacturer
Thanks Teraflex, also one more question. Say I wanted to run the 3" rear Speedbumps, the actual cans in the rear on the 2.5" lift, could i run the 3" speedbumps in the back and trim the rear upper foam pad around 1/2" to compensate for the bigger speedbump cans? Is there a better way to run this setup or am I just barking up the wrong tree? Sorry for being annoying, Thanks y'all!
-Andrew
-Andrew
As in prerunner style do you mean run another set of front speedbumps with a mounting sleeve in the rear? Also do those speedbump caps slide right into the existing rear upper slot where the foam usually is?
Correct, a set of 3" fronts that mount into a sleeve that is welded in place. Yes, the caps just pop in place of the rear upper bucket where the stock bumpstops where.
Thanks! Its all starting to make sense in my head now hahaha. I think I'm going to run the 3" cans in the back with the new strike plates because I'm not really interested in welding anything into place. I know the 2.5 microcell pads are probably the best bet but deep down I know if I put those on I'd kick myself for not putting the cans on because really they are just that much cooler hahaha! Thank you for all your help!
-Andrew
-Andrew
Thanks again Teraflex, I looked into your rear prerunner speed bump kit with the mounting sleeves and am kinda getting hooked. I called a handy neighbor who owns a racing team and said he'd be more than happy to weld those mounting sleeves. They mount right onto the inside of the frame correct? A simple sanding is needed to remove debris and rust and weld away? Im only asking because I want to make it as easy as possible for my neighbor since he is doing it as a favor. I guess what I'm really asking is the Prerunner rear speedbump kit compatible with a 2.5" lift? Do I need to position the sleeve in any particular way/height in order to install properly before the welding gets done? Once again thank you for your time, My Teraflex 2.5" coil lift and monster front track bar have been amazing so far and I look forward to continuing my Teraflex experience!
-Andrew
-Andrew
