2009 JK X best wheel bearings?
Old 10-23-2014, 05:29 PM
joentuff's Avatar
Default 2009 JK X best wheel bearings?
ok i am about to replace my wheel bearings and want input on what the best ones are for my Jeep, I have a dana 30 and im running way to big of tires (38s) but about to drop down to (37s) so I know these will always go out but which ones will last me the longest?
Old 10-23-2014, 06:46 PM
ronjenx's Avatar
All the replacement front unit bearing assemblies I have seen are made by Iljin; same as OEM. Even the ones sold by Timken have all the same Iljin markings as OEM.
So, shop for price and warranty.
Old 10-24-2014, 05:59 AM
TheDirtman's Avatar
spyntec
Old 10-24-2014, 11:19 AM
silversurfer575's Avatar
If your talking about this:
Timken HA590242 Wheel Bearing and Hub Assembly
Then StockwiseAuto on Amazon has them for $89.04 each. I bought a set. Identical to OEM and has Timken bearings. Only issue is that the wheel speed sensor wire is too short. You can re-use your old ones or buy a Mopar one for around $20 each.
If money is no object, you can go with Spyntec, as The Dirtman suggests.
Old 10-24-2014, 11:27 AM
TheDirtman's Avatar
he did ask for "the best"
Old 10-24-2014, 12:19 PM
ronjenx's Avatar
What did you see that indicates it has Timken bearings in it?
Old 10-24-2014, 01:07 PM
The title.
Did you go to Amazon and check it out?
And by the way, they came in a Timken box.
Old 10-24-2014, 01:08 PM
lol! true dat!
Old 10-24-2014, 01:32 PM
ronjenx's Avatar
The title.
I have one in a Timken box. On the box is the part number you listed.
A close look at the part in the Timken box reveals all the Iljin markings of the OEM Iljin bearing assembly.
Take a close look at the ones you have.
Old 10-24-2014, 03:26 PM
To me thats not important enough to get excited about.
Quick Reply: 2009 JK X best wheel bearings?
