2008 JK Won't start unless I shift through gears
Old 10-16-2023 | 09:07 AM
Woodsie's Avatar
Default 2008 JK Won't start unless I shift through gears
Any help or ideas would be greatly appreciated. This happens intermittently when I go to start the Jeep, it will begin to crank but will not turn over. If i keep the key on then shift down through all gears (automatic) and right back to park, I can then turn the key off and turn it back on and it will start. I had the starter replaced but did not fix the issue. this seems to be the fix every time, once I move the shifter all the way down and back to park. This may happen once every 2 weeks or on back to back days. No pattern. Thank you for any advice.
Old 10-16-2023 | 09:19 AM
cartoscro's Avatar
Sounds like your Transmission Range Sensor is going out (TRS).
Woodsie (10-16-2023)
Old 10-16-2023 | 09:24 AM
ronjenx's Avatar
Run an additional ground wire from the battery negative terminal to one of the alternator mount bolts. See if that changes its behavior.
Old 10-16-2023 | 09:31 AM
Woodsie's Avatar
thank you!
