2008 JK Rubicon Unlimited Lift??
What are the differences between Coil Lift, Short Arm, Mid Arm, & Long Arm, and what are the pitfalls and benefits of each?
Also, I saw in the FAQ's For Newbies, that a lift with that comes with Cam Bolts, is not recommended and you should use adjustable upper or lower front control arms to reset the caster. The MOPAR 2" Performance Kit comes with cam bolts. This is the kit I was going to buy until I saw the post about not using cam bolts. The post talks about having to notch out the lower control arm mounts.
What I really want to do is run 35" tires. Install a top quality suspension lift to get the room and increase articulation. I don't want to use a budget lift (spacers only), nor do want to modify by cutting or welding on my jeep.
What is the absolute best way to go to maintain stability for on road and good offroad performance as well?
Thanks in advance for any assistance.
JK-Forum Founder
