2008 Jeep JK Keeps Blowing Rear Shocks
Hello. I have a 2008 Jeep JK with a 4" lift and 35" tires that keeps blowing rear shocks. I pull my boat with it, as well as an R-pod RP-176T RV. The RV's tongue weight is only 278lbs according to the manufacturer. Has anyone had this issue before? I believe it's the RV but I am not certain. I have replaced the shocks twice now in a span of 1 year. If it is the RV is there anything I can do to resolve the issue? I have never gotten it weighed at a truck scale, so have no idea of the total weight but was told it was well below the GVWR of my jeep which I believe is 3500lbs. I do not have a stock rear bumper, but instead a Smittybuilt XRC bumper.
Any info you guys can provide would be great. I am fairly ignorant when it comes to shocks.
Thanks!
Thanks!
You've got proper bumpstops and limiting straps for the rear axle, correct? That *may* be part of the problem but it sounds like your shocks are having a hard time handling the load.
If that's the case then some air bags in the rear would help you out. They're relatively cheap, $100, and it'll firm up the rear end so there isn't as much of a load transferred to your shocks.
Also...what brand/ type of shocks are you running? Some Rancho 9000x's might be a good choice for you between the adjustability and warranty.
Like asked above, what shock, are you properly bump stopped and limited so that you not bottoming the shock at full extent or full compression? Are you "blowing the shock" as in leaking oil, or are you breaking the piston free inside the shock body and the shock is going limp? With the setup done correctly, even a parts store shock should last a few years.
My experience has been that slowing down the coil bounce by stabilizing the coil then reduces the extremes that the shock absorber sees.
Again- from experience pulling a trailer that is a little heavy.
Thanks again everyone!
I don't have very much knowledge about the whys or how's, but I can say this. I blew 3 sets of the procomp es9000 shocks in the rear in the 1.5 years I had them on my jeep. My bump stops were sized correctly too.
