2007 jk wrangler 4-5 inch lift need?
if i put a 4-5 inch lift on my 2 door jk will i need a new driveshaft? i was thinking of putting skyjackers lift on my jk. goal is to have a smooth ride and bigger tires maybe 35 inch. if you have any recommended lift i should do id appreciate it. my budget is like $800. thanks
regarding your question, it's like what everyone has already said, anything more than 2.5" of lift and you're gonna need new drive shafts especially being that you have a 2-door.
as far as the amount of lift you want goes, i gotta tell you that 4"-5" of lift is A LOT of lift for just 35's. at that height, you can run 37's and, to do it right, you'd should expect to pay 3 to 4 times more than what you've got budgeted. for your purposes, you should really look into getting a 2.5" budget boost and maybe a 1" body lift as that will get you clearing 35's without any trouble and can be done in the budget you have.
last but not least, listen to others on this forum who've had experience with skyjacker and stay away from their kits.
welcome to jk-forum!!
I have a 2008 unlimited and was going to try flat fender flares, different back spacing, cutting the body pinch in front of rear wheels with 35's. I'm hoping I can do this on stock suspension
