2007-2011 performance with 285/75/17 Toyo AT2 Extremes?
What are others with 2007-2011 JKU's experiencing going from stock tires to Toyo AT2 Extremes in 285/75/17 size. Please don't provide info on MT version or other tires/sizes.
I have 2010 with 3.73 gears, automatic, 3 inch lift and not looking to regear. I also have an SC Flashpaq. They weigh in at 63lb (15lb increase from BFG MT KM1 @ 48lb) which isn't light, but doesn't sound ridiculous at this size. Also a somewhat narrow tire which should limit additional wind resistance at highway speed.
Any specific experience with this size, model, and setup would be helpful. Sounds like these are a hot tire and size at the moment so hopefully this will help others considering to make the move.
There is no P rated version in this size, only E which equates to the Extreme version and E weight rated. It is a significantly different tire due to tread and sidewall design. These are the tires I'm interested in.
I have that tire. I went from the stock 18" wheels with stock tires to 17" wheels 285/75/17. I have a 2009 Sahara auto and had just slight power and brake loss. I think I lost about 1-2mpg and speedo is off 3mph at around 65mph when using the gps. My spare fits by using a $12 5/8" wheel spacer from AutoZone. I love these tires ride nice at 31psi and are quiet. My only regret is that I wish I went with the 35X12.5. Although my tires are wider than stock and look great the performance loss was so little I think my jeep could handle 35s. Did I mention I went winter wheeling recently and these Toyo's were did great.
I went with those exact tires and absolutely love them. Great look, quality ride, very little noise and apparently they last forever! At this point, my only regret is not getting the 35's instead... these are effectively a 33" tire. If you aren't running a bumper/tire carrier, I would look at getting the MBRP Spare Tire Reinforcement Kit as well. I'm glad I did.
Correct!! The spare rubs on the bumper just enough to give it some support. I have a Sahara son I have that silver cover not sure if it will rub without it. It's hard to judge my mpg because I did not use a procal so my mileage computer and odometer are a bit off. These tires measure 33.1 in real life they look way taller than my friends 285/70/16 coopers. Good luck!!
