2 inch lift and 33...now vibration and noise
Old 10-25-2012 | 03:33 PM
mrmason's Avatar
Default 2 inch lift and 33...now vibration and noise
Put on a 2 in daystar lift and 33 inch Nitto Graplers and getting a lot of vibration and noise when in idle reverse. Also getting some noise and vibration in idle D but not as much. Could be gears or timing? It's a brand new 2012 unlimited. Any help pleas. Thanks!
Old 10-25-2012 | 03:43 PM
otservice's Avatar
Could be a coincidence or maybe something is loose under there. Turn the Jeep on and get underneither and see if there's any obvious loose bolts, brackets, exhaust etc that could be causing the vibration. Check all bolts on the suspension as well to make sure they are all tight. Put the vehicle up on jack stands (all 4 wheels in the air) and have somebody put it in D and let it drive itself while you watch the driveshafts turn and look for anything that isn't right.
The other way to do it, is just take it to the dealer if it's new.
Old 10-25-2012 | 07:01 PM
mrmason's Avatar
Thanks for the info...I think I am going to take it to dealer...in park or neutral it doesn't do anything....
Old 10-25-2012 | 07:17 PM
courtsm3's Avatar
check your exhaust
Old 10-25-2012 | 07:31 PM
1978cj7jk2012's Avatar
Will the dealer still look at it under warranty now that it us lifted??
Old 10-25-2012 | 07:48 PM
Jeek.OlllllllO's Avatar
If they arent friendly i think they void your suspension warranty only
Old 10-26-2012 | 05:38 AM
True that. But I've heard of dealerships voiding even the axle and steering components from a lift..
Old 10-26-2012 | 05:27 PM
mrmason's Avatar
It's all warranted had the dealership install it all. They said as long as its mopar it's good. Took it by dealership today. Rear leaf spring needs adjusted. Thanks for the input.
Old 10-26-2012 | 05:40 PM
3min3m2's Avatar
Your 2012 does NOT have leaf springs...
Old 10-26-2012 | 06:48 PM
Robert.frederick's Avatar
Dont think jeeps have had leaf springs since 96....
