2 door rear lower spring mount relocation
Has anyone moved the lower rear spring mount to fix the bent spring problem after lift and new adj arms???
I was told by a guy at terafelx that best way to fix that probelm was to cut the mounts off and re-weld them in the new location...
I just ordered the rockkrawler wedges and jks rear spring retainers today hoping this will do the trick. If not I will be looking at the jks adjustable spring mounts.
I think this is what I am going to do when I get new DS in June/July. I am thinking all you have to do is remove the rear springs, cut off and grind smooth where the old spring perches where, install spring with new perches just resting on the axle, lower the weight of the jk back down on springs, tap the pads just where you want them to correct the bow and weld into place. At least that is how I think it can be done.
I do not know if I will go with Trail Master brand or not, just saw the article and have not had time to even read all of it yet.
