2 Door OME HD Springs on 4 Door
Okay here is the deal:
Considering trading my Modded 2 Door for a Stock 4 Door. Going to take most of the mods off and bolt them up.
Will the OME HD lift kit I have in my 2 Door be worth putting in the 4 Door Unlimited?
Will it lift it at all?
if you have part number 616 and 618 for your 2 door those are used on the 4 door .
The 616 is the standard Front which will give you about 2-2.25" lift and the rear is the same so you are good there.
David
David
