2 door JKR, how much lift before driveshaft needed?
Yea ... The issue is most coils give more then advertised. My front was replaced but still running the stock rear at 3.5 w/ no pinion correction. Your jeep may be different.
I use the RK 2.5" Flex System and mine failed the first time I hit the trails. I guess it depends on how you use your Jeep. Know of several guys that are still running their front drive shaft after it failed.
I'm a firm believer that if its not broke, don't fix it...but if it failed, don't wait and replace. Since I travel almost 3 hours to go wheeling, I'm changing mine right away. Ordered a Coast 1310 and should be here on Tuesday, install on Wednesday and back to wheeling on Saturday.
