2.5bb with stock wheels
Does anyone have the 2.5BB with 35's and using there stock 17inch wheels? I would like to get a 2.5 BB with a 1 inch body lift. Will stock 17's fit with 35s and the 2.5BB? Thanks!
If you are going with the SSR's 35x10.50x17 you should be fine but with any of the other ones that are 12.5 wide you need spacers. Our stock rubi tires are 10.02 inches wide
Stock rubi 17" wheel have 6.25 backspacing, most use eather 1.25 or 1.50 spacers. It also depends on how wide of a tire your are going too. But also if you are going any wider than 12.50 then you REALLLY should think about differant rims as they will need to be at least 10" wide and the stock ones are only 7.5 if i remember correctly.
Someone pleasee correct me if i am wrong.
Kat
Kat
