2.5 teraflex question
Disregard that. If I tossed the rear spacer I currently have and got a 2" spacer to replace it and I kept the 2" spacer I have in the front then in theory I would have a 5" lift up front and 4" in the rear. Now, that being said, would the shock extensions and all the other parts in the 2.5" teraflex coil lift still work given that I'm adding an additional 2" to the lift? If not, would it work if I added just an additional 1" to the lift instead of 2"? I'm sorry if this is confusing I'm just trying to figure out my options. Thanks in advance.
Once you go 3.5" or more you are right on the border of having to do all 8 control arms ( minimum of 4 lowers ), your front DS, as well as brake line extensions and a front adj trackbar, draglink flip kit, etc, etc, etc..
Not to mention your Jeep is a little older so you might start having to replace things like Ball joints soon. This all adds up to some serious $$$$. I love my TF lift ( 2.5" coils and Bilsteins ), but upgrading to a 3.5" or more sets off a chain reaction of things to consider upgrading.
Start with 2.5" coils....you can always go bigger and sell your coils to someone down the road. That's my advice.
I'm running the TF2.5" kit with 1" spacers on top. Love it. Did have to add more parts but have some ideas for you. Let me get home to a computer and i'll type them up....until then do a search I have plenty posted on all of this...from tire carrier impacts to ride quality to driveshafts.... things to consider your jk should hqve come with a stock spacer up front if that is still there you have caj use or rkove in conjunction with the leveling kit and lift. Also what are looking to run tire size? And trail type? 5" could be overkill and costly if you don't need it..I'll post more in a bit.
I have been running the teraflex 2.5" kit for almost 4 years now with 35's.
I trimmed the fenders and all is well. Since I have a 2dr I did not want the
added expense to go any taller.
I am still running the teraflex shocks as well and the have been good.
They are now starting to leak so I guess I will be in the market for new
shocks soon.
shocks soon.
