2.5" Teraflex coil lift install problem
It looks different. I have this lift and installed it some time ago, like it was mentioned above, you don't 'HAVE' to have this bracket installed. I did this lift without installing it and I have no tracking problems or any issues. When I go to a 4" lift, then I will be going with an adjustable, gives you more flexability when it comes to adjusting it.
I just put this lift on and did not use the bracket, as I had already purchased a JKS track bar. It worked out great, and it sounds like that will be the case for you too!
I had the same issue as well. The template was off by a few as you can see by the picture. The top whole was the actual spot were the whole aligned
