2.5" teraflex coil lift + 1.75" rear spacers...or any suggestions
4 door jk with 2.5" coil lift, that came with 1/2" spacer in the rear to level out the rake in the kit from northridge.
Put a LOD rear bumper with Tire Carrier, 35" MTZ and Highlift jack and it seems to be sagging about 1.5" from initial lift. Also adding a ARB rooftop tent in a month or so which will add more weight to the rear.
Thinking I would add a 1.75" spacer (replacing the 1/2") that would net a 1.25" gain.
Anyone see any problems with this?
Does it matter what brand of spacer?
Would I be better off replacing the coils (rear for now, fronts when i get new bumper and winch)?
I have a similar setup, but I am running an XRC rear bumper 35" KM2's and a hi-lift jack on the carrier. I have the TF 2.5" with shocks, removed the rear 1/2" spacer and added a TF 1".
I do have a LoD mid width front bumper and winch, I didn't add anything to the front. Seems to sit perfect with no rubbing when flexed... I have a 2DR though..
