2.5 Spring lift question.
I know, someone is going to roll your eyes since this is a repeated question. but searching I have found no definitive 100% answer. So, sorry in advance gang...
Looking at this eBay buy: Suspension Spring Lift 2007 13 Jeep Wrangler JK 2 5" 4DR and 3 5" 2dr | eBay
If I get it, what else would I need? Would I NEED new shocks for a daily driver with limited off road use "for now".?? Can I get away with adding the springs and going.?
Your current shocks aren't going to be long enough. As for what else you need, look at what a decent 2.5 lift kit comes with. Springs and shocks and nothing else is not something you want to do.
I figured as much.. This is my other interest.
Skyjacker 2" Lift Kit with Hydro Shocks 07 13 Jeep JK Wrangler Unlimited | eBay
TonyJK, what type of spring are those on first post? You could pick up shock extensions if need to be.
I did the opposite, bought the shocks, realizing I needed the 2" springs
Look into the Rancho 2" sport kit. Perfect for 33's. Around 400 bucks with adjustable shocks. Try Amazon
If your getting a 2.5 lift for under 200 run away! You get exactly what you pay for when it comes to lifts. I highly recommend you look into a leveling kit for 33"s. I have 34's with a 2.5 and the tires look to small.
Bump stop extensions. Extended sway bar links. Rear track bar bracket. Shock extensions or new shocks. Just buy a kit that includes the necessary components.
