2.5 RockKrawler on order
Former Vendor
Former Vendor
So while I wait patiently I am installing my shock extensions, worked on rear today. I have to wait a while before I order my new shocks. I had the rear of the jeep on stands and released the shocks. When I lowered the axle the emergency brake cable and brake lines became very tight. Is there some kind of relocation bracket? It looks like when the axle droops the emergency brake cables will bind on the brakes and the gas fill line. Anyone have input here? Also with the 2.5 kit that has the front lower control arms and track bar, you get new front brake lines. On the back it is expected that the existing lines be used. Is there a brake line relocation bracket in the kit? It looks like I will need to let the lines down to keep them from binding. So two issues. Emergency brake cable bracket and rear brake lines bracket.
Any input?
Any input?
RK
I was going to get the 5100 for the 4" lift. With the 2 door I should be a little more than the 2.5" from what I understand so I wanted to take advantage of this with longer shocks. Is this going to cause me trouble?
I waited about 3 weeks for my order but it was well worth the wait. The quality and the strength of there lift will blow u away.
