2.5" lifts or larger sway bar issues
When adding a 2.5” or larger lift to a JK, no matter what brand, there will be clearance issues with the rear sway bar. Jeep has designed the JK frame so wide plus then added the rear sway bar outside the frame, there’s just not enough room. Anytime you add longer shocks to a JK, it allows the axle to droop more which allows it to shift side to side. The only 3 solutions are: wheel spacers, retain stock shocks to limit droop or swap the rims out with those with more offset to them. Most people that go with a larger kit already plan to change out the rims to allow for bigger tires, correcting this issue. Typically the only time the tires rub will be at full droop. Normal daily driving would have no issues. This is normal for just about any Jeep.
i have 4.5" backspacing on my wheels with 33X12.50 tires and not one bit of problem.
i wanna get the teraflex 2.5" bb for my new jk, i have some questions for you: i´m gonna use it mostly as my daily drive, i only gonna do offroad twice a month or a little more; should i get the lift with shock extensions or with the shocks? what´s the difference between the stock shocks to the shocks that come with the kit? thanks
Sorry cormac827, but this issue happens to every manufactor of lifts for JK's. With Jeeps design to give the JK a wider stance, this problem was created. Unfortunately the solutions is more $ for the addtional parts from the consumer.
